1 - 5 of 5 Posts
I bought an 01 intake to turbo my 03. The intake didn't include the gaskets. I ordered replacement gaskets for an 01. I'm referring to the gaskets between heads and lower.
Should I have gotten mach 1 gaskets or will the 01's work?
Moving on up...
You should be ok. One quick way to check is call any ford dealer and check the part numbers, if they're the same, you're good. I think all 99 and up 4V engines have the same intake manifold gaskets.
I think you're going to need the Mach 1 gaskets, the 01's are different and didnt fit my 03.
1 - 5 of 5 Posts
