There is another follow on failure attributable to the sustained chain loading when the engine is shut down.
The sustained chain loading stresses all the links and anchoring pins in the silent driver chain, which is undesirable. It also does something else that is damaging in the extreme. When the engine shuts down, and the primary drive chain tension is not released because of a locked ratcheting plunger, it loads the front cam journal on both sides of the engine pinching off the oil film. The front journal on the driverside is at the end of the lubrication food chain and gets oiled last.
When the engine shuts down, and the primary drive chain tugs downward on the cam nose because the tension has not been released, in the now pinched off oil film between the cam and the head, the #1 cam journal experiences metal-to-metal contact. The repeated metal-to-metal contact continues at each new start and roughs up the cam and the journal bearing in the cam saddle. The cam eventually seizes in the head, and the broken chain, bent valves, and broken guides damage saga plays out.
If you check, many, if not most, broken chain histories will almost always have a seized cam journal in the litany of damaged parts — for the reasons we are talking about. There are three things you can do to mitigate this;
- The Tensioner Mod we have been talking about,
- Use of an Oil Accumulator,
- Use of an oil additive — I highly recommend ProLong
The Oil Accumulator is not widely used or recognized. Canton offers them under the trade name Accusump™ and Moroso as an Oil Accumulator. They can be installed to perform two different functions. The first function is pre-oiling the engine before startup. Both firms offer a kit to allow the oil accumulator to flush into the engine prior to startup. This will protect those tender cam journals that get oiled last. Their second function is to protect from uncovering the oil pickup and drawing air into the lubrication system.
After the accumulator is set up, for example, to discharge below the engine's operating oil pressure, say 45/50 psi, when the oil sloshes to the back of the pan, for example, exposing the pickup, the oil accumulator will begin to discharge its supply of oil into the oil system making up for the temporary reduction in oil volume or quality to the bearing surfaces.
Oil accumulators come in various sizes up to a 3-quart capacity. In general, they only hold about 1/2 of that capacity. Their design uses an o-ring sealed piston with air behind it at atmospheric pressure. As the engine runs, the oil pump pumps oil into the engine, and the accumulator pushes the piston up against the air-filled chamber, compressing it to a pressure equivalent to the engine's oil pressure. Fully compressed, about half or a bit more of the cylinder is oil and the other half is compressed air, so your three-quart accumulator is actually 1.5 quarts or a bit more. Buy the big unit. These things are a poor man's dry-sump!
ProLong and other oil additives are an emotionally charged topic. I was historically an anti-additive guy. I got talked into using ProLong at an NHRA event decades ago — it saved an engine for me, at that event. I have been a ProLong bigot ever since. If you elect to use it buy the gallon bottles off Amazon for $65. They are a better deal than the 12 oz auto parts store bottles for $20.
