1 - 6 of 6 Posts
Anyone know what psi this will push on an S-trim? I know the 3.12" from Vortech is a 12psi. Can't imagine the 3.00" will be a whole lot different.
TIA,
All I know is that I have a 3.33" on a regualar s-trim which makes 10psi (no powerpipe). I want to step up the boost (per Chris Johnson) w/ a 3.12" pulley. I would like to use the Ultragrip which only comes in a 3.00". I'm wondering what the 3.00" is rated for.
right now, reichard's blower pulleys are available in some different sizes, in the 6 rib version vs. the 8 rib version. i have a used reichard racing 6 rib 3.3" and 3.1" vortech blower pulley for sale. i also have a used 6 rib ati balancer for sale. on a stock cobra engine with the 3.3" blower pulley i made 12.5 psi of boost with a v-2, s-trim blower with a powerpipe and 92mm pro-m meter.
If you go to a 3.125 pulley with a power pipe like my setup you will make 18-19 psi @7400 rpms
Are you the guy that CJ tuned with a stock longblock? If so, youv'e got an amazing car dude!:D
1 - 6 of 6 Posts
