1 - 20 of 26 Posts
I have been thinking of going with the Aeromotive one. A1000 style with the -10 inlets and -6 outlet but wanted to get some feedback on what else is out there.
Justin @ Fore Precision already did some testing, and in a triple pump system the A1000 regulator was not the regulator of choice. The regulator that works best with that fuel volume was the Aeromotive Pro-series regulator. Thats what we are including in our triple pump return systems because of Justins research. Of course, you dont have to use Aeromotive. You could use a Magnafuel or other brands equivalent.
The aero piece is of good quality? I know I am a bit iffy on there pumps, that is why I am going to the glenns performance triple pump system. It has been proven to work!
How is the magnafuel products?
Oh by the way I recieved my fore rails that are E-coated, they look killer!!!!!!!!!!
I also forgot to mention that Fore is making his own regulator that will be able to support the triple pump setup and it has some neat features such as a warning light that can be wired to come on when the regulator stops bypassing fuel (this would mean you pumps are maxed).
The Aeromotive regulator is a quality piece, cant say that I have had any issues with that product from them and we have been shipping our return systems with them (will be switching to the fore piece though).
I have heard a lot of good things about Magnafuel, but have no first hand expierence with thier product to be honest. But from what I have read on some other forums, everyone is real happy with their products.
I see that you have only one return from the rails back to the reg, any reason? I was going to bring 2 lines back to the reg, one from each rail.
are You Not Running A Boost Reference Line?
I Too Am Running The Aeromotive Regulator, But It's The Same One Pictured Above The A1000. I Haven't Seen Any Negative Performance From This Regulator, But I Can Only Comment On My Personal Experience.
Yes, I Run The Boost Reference On Both Cars.
Discussion Starter · #13 ·
I just purchased a complete kit form Glenns performance today it consists fo the following:
Glenns performance sumped fuel tank
push lock fuel line and fittings
Y-block
twin walbro pumps
Aero A1000 reg
They said they have had NO issues with the A1000 reg that has the -10 inlet ports so I went with it!
03-sonic, How much power are you running with the twin walbro's? I was planing on the triple pumps but they told me I do not need it, the duel would be more than enough to handle up to 900 rwhp.
Y-block
twin walbro pumps
Aero A1000 reg
He drills his pumps out, they are good for 500hp a piece so you are good for 1000hp.
Discussion Starter · #16 ·
1,000 whell hp on a blower car? I know at the same power levels between a blower car to a nitrous car or turbo car, the blower car will demand more fuel do to the loss of power needed to drive the blower.
Discussion Starter · #18 ·
Now that I went return I no longer need the FPDM in the car correct??
1 - 20 of 26 Posts
