..about to finish it - any pointers?
right now, im trying to decide where to mount the pump, as well as the filters...
sumped tank, A1000 pump, injected return regulator, billet rails
-10 feed, -6 return.
Nathan
Nathan:
You can mount the pump and filters in front of the factory tank (which I assume you are using a sump) using a bracket that CFM (Central Florida Mustang - They advertise in MM&FF) sells for under $30.00. I had that bracket in my car before I went to a Weldon pump and it worked great. The bracket mounts to the bottom of the trunk floor and the fuel tank plastic shroud and it is pretty sturdy to support the Pump and filters.
Good luck,
