have a knocking noise coming from y engine, it made the exact same sound back in dec. and after replacing the keyway, chains, guides, and tensioners it went away, now it's back. could this sound be a rod, oil pressure is fine, no overheating. any ideas?
phil
the keyway was cracked
I cracked one as well and untill I got deep in there and started to turn the motor to get to all the Flexplate/TC bolts I had no idea what it was. The ring lands were the #1 suspect. I guess that's why they updated the two piece crank sprocket design to the stronger one piece unit.
I would turn the motor slowly by hand and see what "ticks".
Good luck,
-Scott
