My idle is jumping from 500rpm to 1100rpm. No leaks, timing chain maybe? Idle is rough as well.
Also rpm's jump up 200-300 when driving and i push in on the clutch could it have anything to do with the fact that I don't have any voltage going to my O.S.S. (V.S.S.)?
Any ideas anyone?
2000 GT:confused:
Do you have any codes or check engine light?Just start?what mods did you do before it started?
ruogh idle
Started shortly after mods were done. Lean condition code but within range.
Mods are: C&L 80mm maf, Mac 70mm t-body, ported upper, Steeda underdrive pullies, Steeda timing adjuster, Mac pro chamber, and flowmaster cat back.
Thanks
Re: ruogh idle
Thanks
Well,
Its possible its the c&l meter.Try cleaning the sensor wire inside and re seat the sensor.
Just FYI the tbody HURTS power(dyno proving this on my web site).
But i had this issue before N\A and it was a dirty sensor in my c&L.
Clean it reset the computer(disconnect battery).Crank and let idle till the coolant fan cycles once.Then it should be fine.
