Unfortunately I am selling my truck. We are building a house and it will make things much easier without the truck for now. I'd like to be back in the game soon, but take a break for a while. I'm going to put it on ebay next week. A Harley truck with less mods went for $40k a month or so ago.
2001 Ford Lightning, Silver, 3000 miles on the truck. The motor was pulled and built with 600 miles on the odometer. It was built professionally with no shortcuts. The only parts I will be removing from the truck are the air/fuel meter and possibly the Zex kit. The nitrous was run once with a 55 shot to cool things down. The truck is 100% pefect. The modifications on the truck add up to well over $20k.
Here are the mods:
JLP Dual Ram Air
JLP Thunder Pipe
JLP Outerwear Filter
JLP Billet Single Blade Throttle Body
JLP Driveshaft loop
JLP DiabloSport Delta Chip
Kenne Bell 3.25"-2.25" upper supercharger pulley
JLP 10lb lower supercharger pulley
ProTorque 2600 Stall Convertor
Factory Tech Valve Body
Electric Fan
Cobra R waterpump
JLP SuperCooler
JLP AFCO Intercooler Radiator
JLP/LPP Long Tube Stepped Headers
Bassani High Flow Cats
Bassani Cat Back Exhaust
JLP Traction Bars
Denso Iridium Plugs
Kenne Bell Twin Screw SuperCharger Upgrade
50lb. Fuel Injectors
Kenne Bell Boost-A-Pump
Dual 255lph in-tank pumps
Zex N20 Kit w/ Purge and Bottle Heater
Cervini Cowl Induction Hood
Cervini Tailgate Wing
Billet Gas Cap
Bed Rug
Weld ProStar XP Wheels
Rhodes Custom Roll Bar
5 Point Racing Harness
Fire Jacket and Helmet
MGW Billet AOD Knob
MGW Billet Tilt Steering Knob
MGW Billet Lighter
MGW Billet Oil Cap
MGW Billet A/C Knobs
MGW Coat Hanger
MGW Billet Turn Signal Knob
Diamond Series White AC Panel
UPR Billet Window Switches
Harley Davidson Door Handles
Harley Davidson Seat Lever
MGW Billet Coat Hooks
SRP Racing Pedals
Lo-Tek 3 pillar pod
Autometer Boost
Autometer Full Sweep Elec. Fuel
Autometer Elec. Air/Fuel Gauges
Steering 2 Gauge Pod
Autometer Elec. Oil Pressure Gauge
Autometer Elec. Water Temp Gauge
FJO Wideband 02 meter with datalogging and LED display
Manley H Beam Rods
CP Forged Pistons
Plasma Moly Rings
Mod Max valves
Arp Head Studs
Arp Main Studs
Fox Lake Stage 2 CNC Ported Heads
Mod Max Stage 1 Cams
Fox Lake Stage2 CNC Heads
ModMax Street/Strip Cams
Eric, Good luck. Ive enjoyed watching your progress and your website. Hopefully the new house has a big garage and room for a 05 which Im sure you will make fast as hell.
