1 - 5 of 5 Posts
KOEO (key on engine off)
  • P0605 Powertrain Control Module Read Only Memory (ROM) Error
KOER (key on engine running)
  • P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean
  • P1127 Exhaust Not Warm, Downstream O2 Sensor Not Tested
  • P1408 Manifold Absolute Pressure [MAP] Sensor Circuit
Continuous Memory Codes
  • P0153 HO2S Slow Response Bank 2 Sensor 1
  • P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  • P0172 Fuel Trim System Rich Bank 1
Do you think I should take a visit to my tuner and see why my PCM isn't working? Can that be the reason why it's throwing all the other codes?
I have a custom Autologic chip if that has anything to do w/ it. The mechanic that scanned it said some of them *might* of been thrown b/c my car was sitting for 4 hours and the engine was cold.....
Thanks guys!
Darren
Thanks guys!
Darren
First one is beacuse you DO have a chip.
Some of the others look like the o2's are shut off or are not working at all. And yes, the engine was cold too, EGR and downstream o2 codes. :)
Brian
So the first one is not bad? It can't be fixed or go away? Removing the chip is not an option for me w/ the engine swap...
Do you think I need to replace my o2 sensors? Which ones? On the header or on the mid-pipe? What side? Which side is bank 1? Bank 2?
If this was your car, how would you go about fixing it? What would you do first?
I'm an idiot w/ all this emission stuff:shocked
Thanks!
Darren
Does it run bad?
If not, leave it the heck alone! I would just disconnect the battery for 10 mins to clear some of those up and recheck.
Brian
Ranger50 said:
Does it run bad?
Brian
It runs fine. I've disconnected the battery several times. The SES light comes back on within 15 miles or so.
I need to get it smogged. I have a guy that will do it w/ the LTs, but he says there cant be a check engine light on. I'm not sure if he actually scans it or what he does to "pass" me. I can reset the computer right before I go in, but won't the codes still show up if he does scan it?
1 - 5 of 5 Posts
