Spark Plug's POLL
  • Denso's
    Votes: 38 12.4%
  • NGK tr6
    Votes: 187 60.9%
  • Stock Platinum
    Votes: 14 4.6%
  • Autolite's
    Votes: 21 6.8%
  • Other
    Votes: 47 15.3%
1 - 20 of 118 Posts
1 Denso's
2 Ngk tr6
3 Stock Platniums
4 Autolite's
5 Other
What plugs should I be running with this setup?
Thanks
I am still running TR6's.....have been since my first upper pulley mod..just changed the gap as the boost went up. When I was at 20 lbs of boost , I set the gap at .030
I probably should have gone with Denso 22's
Hot Rod(Hard to teach and old dog new tricks)Harry
www.HotRodHarrys.com
tommygun said:
NGX TR55IX
NGX TR55IX Is that a Colder plug then the TR6?
tommygun said:
NGX TR55IX
Bad choice! That plug is too hot for this car, even stock, IMHO. Anyhoo, why not go Denso when it's not that much more, plus has an even finer tip, and colder choices?
Discussion Starter · #12 · (Edited)
Tommylightning said:
IT20s with a gap of .035
Tommy with 276 Pulley he is running more then 12lbs..
Why 20's ???when you suggest 22's for 12 to 16lbs
My suggestions for the Cobra.
Tommylightning
12 - 16 psi IT22s @ .035
17 - 19 psi IT22s @ .030
20 - 22 psi IT24s @ .025
23 - 26 psi IT24s @ .020
Tommylightning
Very sorry, I had done a misprint when I posted before and just copied and pasted the info.
12 - 16 psi IT20s @ .035
Snake Charmer
Whats going to happen performance wise if I opt to use, for example, an IT24 with stock gap(.032 If I remember correctly) at 17psi? How is the gap going to affect performance, are there blowout issues if the gap is too large?
Yes, spark will blow out if the gap to big. It happened to me already. And thanks to this forums, I was told what my problem was, (spark gap to big).
Snake Charmer
Here is another question, what will happen symptom wise if you run a plug that is tooc old? Also, if the plug is colder than ideal what affect will it have on your A/F?
Too cold of a plug will yield a miss at low rpms (idle).
--Joe
Snake Charmer
--Joe
Thats what I figured, the leaner the mix the harder it is for the spark to cross the gap and since these things run so damn lean at low RPM it makes even more sense.
Question. Why .035 and not .040? I thought the larger the gap the better to a degree. What gains will I expect from .035 over .040?
Discussion Starter · #20 ·
I have see Blower cars gapped from 45 to 25 and there was no change in power..Gapped wider just made spark blowout..
1 - 20 of 118 Posts
