Hi everyone,
I'm at a crossroad in my quest to upgrade my ignition system. I'm following the recommendation by Ed to resolve my issue above 5K RPM previously mentionned in another thread. I got the MS3Pro PnP for 96-98 Mustang (will create a thread for that later, very impressive BTW). My IGN-4 coil packs from DIYAutotune are in the mail => IGN-4 Four-Tower Coil Pack
They come with male HEI end, like in this picture.
Unfortunately,this is what spark plug wires look like for my year/model:
I need a wire with this boots at the spark plug side, and male HEI at the coil side. As far as I know, this doesn't exists.
My first choice would be to keep my wires, cut the coil end, and crimp one of those connector => https://www.summitracing.com/parts/alm-24140
Or, should I contact Magnecor and have them built a custom wire set?
If anyone used these coil pack, what have you done to adapt your wires? Bonus points if you can provide mounting solution for the coil pack as they are differents from OEM
Thanks!
Thanks!
