1 - 8 of 8 Posts
Hows the install?
This is a link to the install instructions.
S197 Brake Hose Kit Install
Install is easy as can be. I have had these lines for over a year now. Not a single problem with them. Writing the instructions took longer than the install! It really is as easy as unbolting the stock lines and replacing them in reverse.
No other line can compare to these. Just look at the detail that Brian and J&M put into these lines. No universal fittings or zip ties to hold the lines in place.
Doesn't the steeda lines have factory brackets?
They have a factory style chassis mount but they do not have the factory center support bracket. They also use standard -3 JIC fittings that screw into the caliper and chassis mount fittings which could be another chance for the hoses to loosen up and leak. The last thing is we go into so much detail we even have factory style abs wire clips which make our hoses the only true OEM fit & finish.
1 - 8 of 8 Posts
