1 - 10 of 10 Posts
Pete, Do you think it is a good or bad idea to swap the thermostat to a 180 or will that screw up my chip program? Will there even be a benefit? I just worried that the car won't run as well as it does now come warmer weather.
Yes a 180 is fine and will work with your chip, I think these cars come with a 180 , Mine did from the factory,
A 170 may be better I cant see it hurting, I will do that this week
thanks for bring it up , I forgot about it , Probably because of the cold weather, nitro
If you have a Q ask, I dont mind peace
Hey John, come to FL with us I have room ! nitro
Thanks for the quick response guys.
Is it worth it to buy one of those boost bypass kits?
Dont need it , The bump valve mod is good, I do them
nitro
JT said:
03's come with a 180.
JT
John - you sure? When i measured mine, it opened around 195. So did the "factory rated" one from NAPA.
On topic, I do not see the value in messing with the thermos - I think it is overrated and a remnant of the early closed loop days, I also see some potential downsides for street driven cars - for drag race only cars it is not a concern to run too cool. Ultimately, I believe that the end state of engine temp will be the same, based on flow rate, heat exchange capability (radiator), etc. A cooler thermo will just take longer to reach temperature homeostasis.
Yep, pretty sure. I judged from my OBDII scanner, water temp runs between 175-185.
Pete said when he removed his it had 180 stamped on it. Did yours have a stamping on it?
JT
Yeah, it did, and so did the NAPA unit, but they didn't open at that temp.
Anyway, I agree with your scan - the temps I am seeing match yours, and so i am not messing with the thermo.
But could it not be a 190 thermo, and still see those temps? Depends where you measure the coolant, correct? Is the ECT in the themo housing, or somewhere else?
1 - 10 of 10 Posts
