I have a 2.75" RR upper pulley right now, essentially a 6lb pulley. I am getting a Metco 4lb lower pulley. My question is do I need to change the alternator pulley as well? Is it necessary? If I don;t what happens? Is it under charged, over charged? I just want to make sure I'm doing things right.
Get the Underdrive pulley for the Alternator..You will be overspinning it...
Harry,,I see we don't agree..You like overspining blower and alternator...So far so good..Only time will prove me wrong..
I hope your right..;)
LOL....isnt that what this forum is for :D
With our remarks...he has a 50/50 shot :cool:
Hot Rod(overspin my brain too)Harry
www.HotRodHarrys.com
Yes Harry....
Keep both Pulleys,,,but SHORT SHIFT :D
He should listen to you..your faster....;)
hopefulyl i'll be fine, for now i will go with no alternator pulley change. IF down the road I have to replace the alternator, then I will. But lets not think about that ;)
I changed Alternator to a 3.2
No Problems:
Current Mods:
170 Deg Thermostat.
MM full length subs
QMP 3" 304 S/S exhaust With Cats
<http://www.svtperformance.com/forum...ght=QMP+Exhaust>
Amazon Diablo 2 program race/street Chip with switch
Amazon/ Razor 3.10 upper pulley
Royal Purple Lubes Everywhere
Water Wetter in Intercooler
BilletFlow Throttle Body and Plenum.
<http://www.svtperformance.com/forum...pthreadid=25834>
Metco #2 lb & 4 lb lower pulley kit ( 4 lb installed currently )
Metco upper idler lightened modified bracket.
Billet Flow 100MM Idlers (2) and 92MM Idlers (1)
Metco 3.2" Alternator pulley
Reinforced the Rear Seat delete kit with added trunk bulkhead for a kind of sweet big Rotie/lab mix. <http://www.modularfords.com/...=&threadid=1685>
Amazon Stage 1 Filter kit
Denso Iridium plugs IT-20's
Gatorback belt # 4080797
