1 - 6 of 6 Posts
i have just recently noticed a thumpiung noise or a thud down by my brake pedal when i cut the wheel fast or zigzag, it sounds like somthing is swinging and hitting somthing else, checked all my front end parts everything is tight and all ball joints are good can anyone explain what this might be.
Discussion Starter · #2 ·
by the way this isn't my car just though it looked good so i posted it
Possibly a bad motor mount or loose sway bar.
There's LOTS of bolts/nuts/etc under the front-end - did you check them all???
thanks i didn't even think about a bad motror mounti have check and see
right under my brake pedal
1 - 6 of 6 Posts
