This is what I have been able to pull out of other threads hopefully this is helpfull:
Originally posted by RWTD:
93 Octane Pump
17 lbs (3" upper) - 20 degrees
19 lbs (2.75" upper) - (not generally recommended; although *many* run 16 to 18 degrees without issues)
21 lbs (2.75" w/ 2# lower, or 3.0" w/ 4" lower) - not recommended
98 octane
17 lbs - recommend 96 octane.
19 lbs - 23 degrees (I'd say the perfect octane mixture for this pulley combo).
21 lbs - 21
22 lbs - 20
104 octane
17 lbs - too much octane; would require more than MBT spark to keep power from being hindered.
19 lbs - too much octane; would require more than MBT spark to keep power from being hindered.
21 lbs - 23 degrees (recommend 101 octane)
22 lbs - 23 degrees (recommend 102+ octane
Originally Posted by IronTerp
If you pour one 32 oz can of Torco into 15 gallons of 91 octane, you will get 94 octane.
Torco "Accelerator" Octane Mixtures
5gal of 93 with 32 oz of torco = 101
5gal of 93 with 64 oz of torco = 101+?
8gal of 93 with 32 oz of torco = 99
8gal of 93 with 64 oz of torco = 101+?
10gal of 93 with 32 oz of torco = 98
10gal of 93 with 64 oz of torco = 101
15gal of 93 with 32 oz of torco = 96
15gal of 93 with 64 oz of torco = 99
