1 - 6 of 6 Posts
And to be honest..I'm amazed.I would have never guessed that the bottom end would look like this after as many miles as it had,and with the abuse that I put it through.
Now for the pictures:
The factory cross-hatch is still in the bores and is very visible,with no ring groove whatsoever.
The main bearings were in excellent shape:
Same for the rod bearings:
The pistons skirts only show normal wear:
The cylinder heads had very little carbon buildup(that Ford spray can carbon cleaner must work really well),and look to be in perfect shape:
JL
Wow, that is impressive.
I really think it's a tribute to modern design and fuel injection.
I tore the top off of a 302 not too long ago, just for inspection, of course it was only 70k miles, but it also looked great inside, I couldn't believe it. Same story, still had cross-hatch, practically no valvetrain wear whatsoever.
Congrats.
you guy are lucky mine looked nothing like that.
CR Motorsports said:
What kind of oil and filter did you run and how often did you change it?
I bought it new,and changed the oil the next day(with less than 100 miles on it) to Castrol Syntec 5w30.I ran that oil until Castrol changed their formula to a "faux" synthetic,and changed over to Mobil 1 5w30.I always use a Motorcraft filter,and change the oil/filter every 3-4K miles.
JL
1 - 6 of 6 Posts
