I put this over in the SCT forum but no replies so I thought I'd try here. I've got a wierd issue and I'm not sure whats causing it. I have the factory lock and shift schedules currently (except for WOT shifts). On normal acceleration for my truck it would go 1-2-3/lock/4. It does this correctly when I'm accelerating normal. At a slightly higher TP (like going up a hill) it will go 1-2-3/lock-unlock/4. The lock and unlock happens within a second. I originally thought there was a mechanical issue given a new trans and higher stall converter, but when I logged the converter lock flag it showed the PCM locking then unlocking the converter. Looking at the lock schedule it should be locked and stay that way but something is unlocking it. I added the datalog showing the converter locking and unlocking. If you choose rpm and converter lock in Livelink you will see it around timestamp 200.
The PCM code is CXN1 with a MNAE0 strategy. The vehicle is a 01 Lightning with a 4V/turbo swap. The transmission is a factory 4R100 built with a 3500 stall converter. The only thing I'm logging for the converter is the flag for on off. Is there something else I should log or look at ?
Thanks Mike
Thanks Mike
