1 - 16 of 16 Posts
I'm taking my car down to FL for the Bradenton race and this will be the first time that I ever put this car on a trailor. I drove tractor trailors in the past so I am not worried about towing a 3800 lb car. My question is where would be the best place to put the straps on the front and IRS? Don't want to damage anything. Thanks :tip:
Si vis pacem, para bellum
I tie mine down with the A arms, front and back. It works just fine, just make sure you don't to it in a way that the arms will cut the straps.
Should I criss cross the straps at all you think or just leave it straight? Strapping it to the rim looks fairly simple.
If you go to the rim, do it straight, but if you go to the suspension I'd cross them.
I go around the kmember in the front---on the vertical bars above the rack . I have done the a-arms before in a pinch (didn't want to damage the front of a lowered car).
I strap the rear around the axle tubes with axle straps (solid rear). I would probably recommend the wheel-strap method described above.
Good point, Stu. If you go to the front A arms, watch out for body contact.
gotcha!! I will strap the k member and for the rear I will do the rims. Thanks for all you help fella's. :tip:
I still Criss Cross mine at the rear with the wheel straps. On the front of mine I usually have a strap around the k-member that is also attached to the winch, but still tie down the fronts also. My eyelets are back far enough that I can use the factory tie down points.
Just wanted to thank all of you for the input you gave. I made the 1200 mile trip without any issues. I used the rims for strapping the car down and I only had to adjust one time the whole way down. BTW I had a great time in Bradenton.:tip:
When strapping the wheels, are folks using those basket nets around the tire or just a regular strap through the spokes?
Old thread but I just wanted to update. I wrapped a strap under the driver axle, over the diff, and over the passenger side axle (SRA).
Then I just hooked each front strap to the swaybar hole on the front of the UPR control arms. I'm now thinking this wasn't the best idea and in the future I think I'm going to try to wrap the strap around the K member.
I noticed a front end clack when I backed the car out of the trailer.
There isn't much to it. I pulled up on the fender to work the suspension and it didn't make any noise.
I'm way too busy to look into it right now.
I'm not a tight-a-holic on my own car. When it gets strapped down nice and snug I quit ratcheting. Seems to hard on the car for a bumpy trip. Or I'm chicken and it worries me.
1 - 16 of 16 Posts
