I just finished the trans swap and need to finish up the wiring. Where do you guys have your t/b switch mounted and opinions on where its best to mount it.
Alex
Im using a momentary button on the shifter ball. Ran the 2step and the Tbrake to the same button
Get one of the plates that 4sdvenom makes. That way your button and your shifter can be right at your side and easy to reach. He makes a killer setup...
I agree. Kens setup is badass. I had him build me one as well. I changed the switch config slightly. Originally I was going to use the switch on the plate, but figured it would be better directly on the ball so I dont have to move my hand.
