1 - 2 of 2 Posts
I have a 98 cobra with a t-45 and also have a t-3650 from an 03 gt. both are 5-speeds for those reading this and dont know (just covering my bases). my question is whether or not i can do an even swap? since the 3650 is newer and only needs a 2nd gear syncro, whereas the t-45 is gettin pretty tired and needs a full rebuild. if this swap is possible, would the 3650 hold up in a cobra? have a few bolt on mods but im sure im only around 320-330 hp with all that i have done. if it isn't possible or recommended, then where could i find a reman or new t-45 for a decent price that would be reliable. the car is a daily driver and doesnt see the track, as i like to keep my cars for more than a few months. thanks for any suggestions
the speedo wont work right but can be fixed with a speed cal the crossmember will have to be relocated on the cobra to bolt to the t45 but otherwise it should be just fine
also stock on stock t45 and 3650 are basically the same on power capibilites
1 - 2 of 2 Posts
