1 - 7 of 7 Posts
The BarTender
What is the chances of my trans blowing apart and parts flying into the inside of the car possibly causing harm to me? I hate to sound like an idiot here but I remember hearing something to that effect a long time ago. Do I need to get some type of protection to prevent that from ever happening? I'm just trying to stay as safe as possible.
Razor.
You might consider a scatter shield. You're going to need one if the car ever runs quick ETs. I think the rule is 10.99 or better. Might be an 11 second rule though.
I've never installed one - nor had a tranny grendade. To be honest I'm not certain they even make them for the T56.
The BarTender
I'm not sure they make a scatter shield for my car. I have heard about a "blanket" you can lay down around your tranny (Under the interiors carpet) but I am still clueless. I just want to make sure that the car and myself are safe at the track. Nobody seems to have much info on this subject so I figure I will wait until I get to the track and ask some guys there. Thanks for the info. ;)
Razor.
scattersheild
I did not see in your signature what kind of transmission that you are running. What most are referring to is an sfi approved bellhousing. Lakewood has a bh for the t-45, tremec's etc. The biggest fear is not so much as the tranny coming thru the floor board as the clutch exploding and the flywheel coming thru like a buzz saw blade.
The "blanket", which wraps around the tranny is normally for automatic equipped cars.
Hope this helps,
Ben Dorn
The BarTender
Re: scattersheild
Hope this helps,
Ben Dorn
Yes Ben that helps allot man.:D Right now I am running the Tremec 3650 in my car that it came with from the factory. I have a good feeling that I will break the input shaft on this tranny once I take it back to the track this season with all my new found power. If it does break I have already made the decision to swap in a TKO instead of rebuilding the 3650. A fellow racer with a similar car has already done that and has had nothing but success with the TKO.
What I was most concerned about was the flywheel coming through the floorboard as you mentioned. Last season when the car was stock I blew the clutch on the cars 5th pass down the track. The car was fairly stock at that point and I was running the stock clutch as well.
Do you think I should contact Lakewood for a bellhousing? What are the chances of the flywheel buzzing through the floorboard and how often does that happen? Thanks in advance for the info.
Razor.
There are quite a few vendors out there that sell the Lakewood bellhousing.. I would shop around to see what kind of price and availability you can get. Contacting Lakewood is not a bad idea either.
I cannot give you an answer on how often it happens but I do know it happens. It generally happens on higher hp cars on a hard launch. I have seen pieces of the clutch/flywheel assy go thru a steel fendered car (happened at Kilkare Raceway in Ohio) and hit a girl in the next lane in the helmet.
I have had quite a few tko's in my cars and I am sure you will like them.. On a side note: McCleod is supposed to be coming out with an SFI approved bh, but.... I have been hearing that for a number of years.
You may also want to call D&D performance and talk to Don Walsh Jr. He has the trannies and the related parts you may need for the swap.
Ben
The BarTender
Thanks for all your help Ben.
Razor.
1 - 7 of 7 Posts
