First, this is not about the Terminator but I felt this is the most adequate sub-forum for this question.
I understand what the TCC do. My question is, while drag racing, when should I use it ?
I have a 4R75W with a Circle D multi-disk 4C converter (3600-3800RPM). I've found that I have to setup the shift point very early because of converter slip. Example, when I get close the rev-limiter in second gear, because of converter slip, I can lock the converter and the revs drop a couple thousands RPM, so I can continue in 2nd gear instead of shifting into 3rd. I think it's faster this way than shifting to the next gear.
When in 3rd gear, I can pass the finish line without locking the converter. Should I lock it ? When ? Do I aim to lock the converter to keep the rpm as close as possible to the peak torque (not hp) ?
I understand I need to do trial and errors, but what is the average rule of thumb, to give me a ball park ?
Thanks
PS: Bonus question. What is needed to modify in the valve body to allow the converter to lock in 1st gear ?
Thanks
