What type bell housing do you have to use to install a tremec 3550 in the 97 Cobra? Do you have to go a blow proof or is there an aluminum bell housing available. Does the 5.0 bell housing fit for the tremecs on the mod motor??:confused:
There is a aluminum bell housing available for the swap now but I suggest going with the blowproof housing if you can. The bellhousing for the 302 will not work, it is all together different!
Chad
Thanks. I was thinking of the blow proof and shouldn't be a big install problem with shorty headers.
