Late December I decided to kinda rebuild the car. New shortblock with fresh teksid, same cobra crank, Molnar Turbo rods, custom 3.557 Racetec pistons, same 38 cc TF heads, new custom cams and a slightly modified Reichard Racing intake. Then while I was waiting on parts to arrive I decided to remove weight from the car. I bought a 417 motorsports front tubular section, flaming river manual rack and their shaft kit. I choose a strange master cylinder for the manual brake swap. I've replaced the factory steering column and wheel. I've removed all the factory wiring from the engine bay and under the dash. I've removed half the frame work for the dash. Removed all the padding under carpet and on the firewall. I removed the lambo door kit. It weighed 32lbs alone. I remover the door crash bar. Also removed the rear crash bar and everything attached to it.
