i have a 95 lincoln 4.6 dohc motor which i am doing a c-head swap on so i can put it in a foxbody. and i was wondering if you turbo 03-04 cobra guys had to switch to 99-01 cobra front timing cover or were you able to retain the 03-04 timing cover?
ALSO i am FULLY BUILDING my motor(in the future. now i am only running forged pistons), im going to stroke it out to 324 & run the fr500 heads & crower stage 2 or 3 cams, with supporting fuel mods and i haven't decided on whether or not im going single turbo or twin turbo. but if i went single would you guys say a t88 or t80 would be out of the power band for the street?
I am ussuming by '95 Lincoln, you mean a Teksid block.
The timing cover from the 03 will work just fine. There is one extra hole in that timing cover, that the Teksid blocks don't have a threaded hole to accept a bolt for. Simply fill the hole in the timing cover with a little RTV to seal it off.
An 88 would be a horrible choice to use for a street car.
thanks guys. i guess i didnt do enough research. yes it is a teksid block.
why would an 88 be a bad choice for a street car? its 600 pounds lighter than a cobra but with just as much power.
It will take forever to spool that large of a turbo on the street.
