Two Precision journal bearing 5857 turbos. 60 trim, .63 a/r, upgraded t-31 wheel. These turbos have internal wastegate 5 bolt housings on them. In lieu of the Ford 5 bolt internal wastegate assemblies, these turbos have the "Ultimate Internal Wastegate" by ATP Turbo. They have also been ported, are larger, are more streamlined and perform significantly better than the Ford design. As you can see, they also have a v-band flange for better flow unlike the Ford unit. They also have upgraded dual port wastegate actuators with compact custom brackets. So no external wastegates needed for a more cost effective and simplified set-up. No loud wastegate dumping either!
These turbos were rated by Precision at 575 HP each. I had thes eon my '98 Cobra for a short time and they made 980rwhp. That's right at about 1150 HP at the flywheel right where the turbos are rated. They can make some serious power. They only have less than 300 miles on them. They also include the filters and clamps and the silicone connectors seen in the pictures.
$600 shipped. PM if interested.
[url=https://flic.kr/p/2gn4X8L]
[/url
[url=https://flic.kr/p/2gn5nW9]
[url=https://flic.kr/p/2gn5nUA]
