Need a little guidance on Valve Spring Selection, setting up a new set of heads.
Correct me if I am wrong but the OE Springs are about 70 lbs on the seat.
Ferrea Stock diameter valves. Cams are custom, .472 lift and not much more than stock duration since I want to retain the ability to pass CA Smog (it does).
At 6300 rpm and 25 psi boost, any guesses as to what seat pressure I will need? What is the consensus on the Comp Cams 26123 springs, any good?
