I was curious, whats the max PSI i could see out of my v1 s trim?
I ask because i have a boost gauge reading 13psi now and the gauge is 30vac and 15 boost. If i pulley the car i think i would peg the boost gauge, but i thought i herd s trims are good to 16 psi, that means my gauge could be 1psi short lol...
hum..
I think there is some one here making 16# with a v1.
I do believe that 16psi is about the max you will see out of that blower. You can always upgrade to a si-trim or t-trim if you need more.
Anything over 15psi on your typical 302 H/C/I setup, is just blowing hot air with the S-trim. An Si or T upgrade would alot better for over 15psi.
