1 - 17 of 17 Posts
I'm still running the stock pulley and tune with only the mods listed in my sig. Just wondering what Denso's I should get if I were to swap out my plugs? What should they be gapped to?
U.M.
Stock Heat Range is IT16's.
Snake Charmer
I wouldnt waste money on denso myself, go with a good copper plug.
OK, so IT16's are the same heat range as the stockers. GAP at 0.040" is still the recommendation?
U.M.
Snake Charmer
U.M.
I beleive they are the same heat range as the agsf22's but not all 03's came with them. Mine came with 22's but last time I checked with ford they recommended agsf12's which are a step colder than the 22's. :shrug
So are you saying I should go with the IT20's versus the IT16's?
U.M.
Snake Charmer
U.M.
Im still trying to formulate a decision on this very question myself so Im not trying to tell you to go one way or another. All I trying to do is share some knowledge so you can make a better choice for yourself. I have seen at least 2 different plugs in 03's and I have heard other say there are actually 3 different plugs that came in them. Mine came with 22's and if you call ford now they say to use 12's. I have heard from one tuner that he felt 12's were too cold. Denso says to go one range colder per 75-100hp over stock. I just pulled my 12's and 2 of the 8 were fouled so I dont know if it was due to them being too cold or not? I replaced them with some autolight copper plugs and will check them this week to see how they look. I had IT 24's in my car for a while and it stumbled bad, but I had an exhaust leak too and a slow to respond O2 sensor so not sure if it was the plugs or not, I changed to the agsf12's at the same time I replaced O2 and fixed exhaust leak.
I'm currently running TR-6's, damned if I remember what series my stock plugs were though. It was a 2nd run Cobra if that helps. I should be getting my snake back from the dealer today or tomorrow (head swap). They installed a set of JBA shorties while the motor was out. I was thinking about pulling the TR-6's and replacing them with Denso's.... I guess I'll need to look at how the old plugs are burning before making any changes...
U.M.
My Cobra came with 32's,,Then Ford went to 12's then changed again to 22's
From Cobra Spec Sheet::
Engine Ignition
Ignition timing 10 degrees BTDC ± 2 degrees non-adjustable
Firing order 1-3-7-2-6-5-4-8
Spark plug gap mm (in) 1.32-1.42 (0.052-0.056)
Spark plug type AWSF-32EE
Snake Charmer
Engine Ignition
Dang, .052 seems like a huge gap for a blown engine doesnt it?
Stock only 7.58 Boost, but it does seems like a wider gap then most would use..
Snake Charmer
Isnt that the same gap for all the other stock mod motors?
YEAP!
The 03 Cobra came with three heat ranges of plugs, AGSF-32/22/12s. Mine came with AGSF-12s. I now run IT-24s with no problems. I also run a Plasma Booster.
AMB
1 - 17 of 17 Posts
