What ratio gear would you suggest I install in my 03 Lightning?Also will the motor hold up to the Kennybell S/C or would I have to do internal work?
Leave the stock gears in it.
A stock motor will hold up fine at low boost levels (under 12 psi). But if you want to go balls to the wall then a built motor better be in your future plans.
--Joe
Hey Soap Whats up.
I run on 14-15lbs on the street on BAD 91octance CA gas
And on the track I run 21-22lbs on 105 octane
It's all in the tune if your not tunned for the boost you want then you will get a vented Block:)
Stock Motor, Tranny and 3.55's
PEASE!
