I need to find the best fuel cell for the '97. I'm going to put it in the trunk and I assume that I need one with the pick-ups in a sump on the bottom. I know RCI, Summit, and Fuel safe sell them but which model is best and are there any options I need to make sure and get, ie. trap doors, check valves, etc... Thanks!
Fuel Safe is the only one that will mount in the stock location without major fabrication, but it is also in a different price league.
Also the most capacity...if you're drag only it doesn't matter but the extra fuel is nice for a street car.
I run a triangle engineering tank. Its 15 gal and they made it with the ports that I wanted. I have 12AN to my pump, sending unit to my specs, foamed, with a return. I made a mounting plate out of aluminum for it to sit on. It took some thought to make it look good and fit right.
Hope that helps
thanks
Dave
