1 - 7 of 7 Posts
What does it take to run 120mph? I have a Densecharger, 3.1 Pulley, Magnaflow X (w/ Cats) and cat- back. Should I change to a 2.8 pulley or add a lower? Any help would be appreciated.
Jess
PS I ran a 13.1 @ 114mph on Fri with 19's. Those tires are gone now, they were like glass on the track and street.
ok hope this helps ..I got 121.6 with a
magnaflow catback
magnaflow cats
diablo chip
lightning pulley 2.93
and a conical air filter
ive seen guys go 120 with what i have above and the stock cat pipe good luck.
im not sure and i didnt see it but if he threw a pj performance plug in there im sure it was deleted. rick doesnt do that and he is the moderator so why should pete ba able to
Chill Factor and Matt,
Since I trust your opinions, do you suggest the 2.93 pulley vice a 2.8? Is there less belt slippage with the 2.93? There is nothing worse than showing up to the track and having a car IDENTICAL to yours run 6 more mph with a dumbass driver that doesn't know his [email protected]# from a hole in the wall, it happened to me on Fri.
Later
Jess
1 - 7 of 7 Posts
