1 - 16 of 16 Posts
With D&D K member...
Spring Rate and Size...??
Discussion Starter · #2 ·
I had 150lb Springs for a year,,,They Collapsed..Don't want to go too much heavier......
Jimmy---
You can get either 175lbs springs from D&D or 225lbs springs...I think with the 175's, you should be fine...
Jeff
I run 175# 14" springs up front but I have Koni DA's that help with adjustability. In a light spring, the 14" length is important vs. a 12" heavier spring. I think 175# is a light as you want to go if the car needs street driveability.
I have the Qai Adj,,,so 14in 175 should be ok then...
thanks guys..
I have 175's on mine and I think they are too light. I would opt for stiffer springs if I drove mine daily.
I'm using 175#, 14" springs on my car with no problems.
Bill
I found 200lb Springs ,,Going to try them first..
Good idea Jimbo! If you decide they are too much for your car I will trade you my 175's for them.
Discussion Starter · #12 ·
Deal!!!;)
Discussion Starter · #13 ·
200lb Springs are on..Car sitting high.I'll let it sit(SETTLE) a few days then adjust ride height..I'll let you all know how it rides...
I run the 200's on the front and a 175lb in the rear. The 200 is still pretty soft with a 70/30 coilover shock but it seems to work quite well.
Discussion Starter · #15 ·
Thank's for your input..I am trying to strike a balance between ride and launch..
Discussion Starter · #16 ·
The 200lb Springs work good...
1 - 16 of 16 Posts
