1 - 11 of 11 Posts
Hey guys, I was thinking about going with some Denso Iridium sparkplugs in the near future when I go have the car re-dynoed at JD's Auto and High Performance in Huntington Valley, Pa.
I have a 2.93 upper pulley, I would estimate I am making about 14lbs. of boost at this time with my other mods in sig. I have my NGK's at 0.35 right now, but I have heard that people are going to 0.38-0.40 with the Densos with no problems. I know they supposedly come "pre-gapped", I think it was TommyLightning who can gap them? Should I get the IT-20's or IT22's?
So, what gap should I get them "pre-gapped" at? Or maybe I can have TommyLightning hook them up, if that's the guy to get them from. Any thoughts? 0.35? 0.38?
Figure if they are worth a few more ponies, it's worth the shot right? Thanks guys!
I have heard that Tommy can hook you up and send them pre-gapped (extra $5) based on your application. Look on his web site.
I use the Denso IT 20's gapped @38....
Pushrod Dinosaur
22's here @ 36 Was using the 35 gauge, but was too paranoid to break em. So 36 is what they prolly are.
gary
Ok what is the difference between the IT20's and the IT22's???? Outrageous recommended the 22's and Jim V. recommended the 20's..... ?
The 22's are colder then 20's. Talk to Tommy and ask him what he recommends for heat range and gap he will treat you right. It is well worth the $5 to have him gap them at over $10 a plug it is to easy to break them. I ordered mine from him and am happy with the experience.
Tommy recommended IT22'[email protected] I will stick with that. Gonna dyno with same combo as last time (except for catted x-pipe), and see what happens.....going to JD's Auto Repair and Performance in Huntington Valley, Pa. by the way.
Reason i use the 20's,,,Even with a 2.93 pulley seeing 14lbs at times..You only see 12 @ redline..The 20's are one step hotter then the 22's..
Guys with 19lbs boosted KB cars use the 22's..
I checked my plugs after 8k miles and they were fine..so i'll keep useing the 20's until i up the boost..:D
So what would the ADVANTAGE of using 20's be? I am not a spark plug guru by any means......sorry.
I believe,,You shouldn't use a Plug any colder then you need.Also why gap it any closer then you need..
Works for me:D
1 - 11 of 11 Posts
