While I've got everything apart I decided I would Gasket match the lower intake bowl, & smooth out the casting roughness from the whipple inlet & outlet plate.
Once I got the outlet plate off I saw some cut marks and a thick edge that didn't make much sense regards to flow.
Once I radiused one half of the thick edge I was really surprised at how much that opened up the outlet area. I removed the sharp cut from the walls & blended the walls into the opening under the thick edge, then I removed the casting roughness with an 80 grit flapper wheel from the ramp. I removed the casting roughness from the underside of the plate using an air grinder with a surfacing wheel & 80 grit.
I'll go back over everything with 120 grit flapper & surface wheel then again with the little brillo pad looking surface wheels.
