i am gonna be in a burn out contest this weekend and i found some crown vic wheels with tires and since i don't wanna burn my $200 tires off i will get these if hey fit ($30 for both)
Well the michelin book says 5 on 114.3 or in americanesse that'd be 5 on 4.5 inches which is the same...
What you need to do though is check the back spacing with a tire mounted so you can see if it clears the body, exhaust, ect.
The backspacing will be close, but I think the pre-03 wheels will stick out slightly. IIRC the Vic wheels have a 15mm offset. I think stock Mustang wheels are 24?mm. I bought 0mm offset wheels for my Vic. I knew the 24mm wheels wouldn't work.
Also make sure that they are 16" 98-02 wheels. Pre 98 wheels were 15" and you'll have to ensure they will clear your brake calipers. 03 wheels have 54mm offset.
they don't clear my breaks were 15's ole well i'm sure there will be more burn out contest in the future
