1 - 20 of 141 Posts
Thanks, If you can post up the Body connector harness pinouts for the 96 GT, that would be great.
I use All Data, and sometimes finding the exact connector you need is a pain in the ass if it is not labeled properly. The PCM pinouts are easy.
95 Mustang GT chassis, please
I have a 95 Mustang GT and I was wondering if you have the harness diagram for the dash specifically and the power supply harness in the engine compartment. Thanks!
Hi Eric,
I'm going through a lot of troubles with my 2002 GT 5spd and wondering if you could post the engine harness (Injectors, COPs, etc.) and PCM pinout diagram.
Thanks!!
Riley
Eric
Can you post the wiring for a Lincoln Mark 8? Also, would you happen to have a wiring for the diagnostic link connector? I beleive I am missing one wire. I am building a 63 Continental with a modular, also it will have a 5 speed auto tranny from an Explorer. I guess I will have to use a manual transmission Mustang computer and a seperate controller for the tranny (which I think I have found) Would I able to use a 99 and later computer? I know that it has a fuel pump controller circuit instead of a relay. Would I still be able to use it? Sorry for all the questions. Thanks Gus
1 - 20 of 141 Posts
