2004 Mercury Mountaineer. 4.6L 2v, 5r55s trans, AWD 180,856 miles and counting 73 miles more every day.
Mods: custom intake piping from Moded stock Air box to TB, Trick Flow Intake Manifold Elbow, upgraded COP's, high flow cats, and full exhaust.
I've done some digging into my "tick" and "knock" and they are inter-related.
the Tick, sounds just like push rod lifter/valve train. its constant, matches rpm, and eventually is a barely audible above 2,000rpm at steady cruise.
the "knock" is at cold start up, sounds like it back by the flywheel/converter is only for maybe 2-3-4 revolutions, then is gone. BUT once fully warm, the "knock", is present when you are in drive at the stop light. If you put the SUV in park, at the light, the knock goes away.
the tick has me thinking tensioner(s) , chains, & guides. at 180K, how long are the chains good for? tensioners and guides are wear parts, I have no issue replacing them. Question: upgraded replacements for all the timing pieces out there? brands? vendors? anything to avoid, of just get Ford parts and call it good?
the knock has me baffled. Is it the converter or flexplate? is it rod bearings? At the same time magically as the Timing pieces?
I am all ears... open to any and all experiences.
Rob
Rob
