6 Bolt vs. 8 bolt crank
2 reading
30K views 29 replies 9 participants last post by  stylin99
#1 ·
Does anyone know the pros and cons of 6 bolt and 8 bolt cranks? I bought a crank and its a 6 bolt instead of an 8 bolt and I was wondering if there was performance differences or problems using it with a 99 drivetrain. Thanks
#2 ·
6 bolt cranks are cast and can handle a decent amount of power. Some have seen success with over 600 rwhp but you are assuredly on borrowed time. 8 bolt cranks can be either cast or forged so be sure which one it is before you buy. The main thing is to replace the weak factory rods and pistons if you are planning on making BIG power. But if you are willing to spend the money on a good set of rods and pistons, don't get frugal and just buy a forged crank also. Less headaches later on and the peace of mind is worth a lot.
#5 ·
The only difference with a cast 6 bolt, and a cast 8 is the flange. Strength is the same.
#6 ·
I thought the 6 bolts were for automatics and the 8's for sticks, no?
#9 ·
The reason I thought that is when www.karkraft.com had some original new mach motors for sale they said they had the 6 bolt cranks which were for automatics.
#8 ·
The crank has nothing to do with the transmisson. It only means how many bolts hold the flywheel to the crank. The flywheel is the only thing that matters. If you have a 6 bolt crank you need a 6 bolt flywheel. The stock crank is fine to 500. Probably more.
#10 ·
I think they use a steel crank in the Mach 1 manual. But I'm not sure. I could be mistaken. I really don't keep track of that stuff.
#11 ·
Stock GT 6 bolt crank is good to 7000 RPM's. If you don't twist it any higher than that you don't need a forged 8 bolt crank. Also be aware if you go to a 8 bolt crank you will have to buy an 8 bolt flywheel as well.
#12 ·
Just because I like to know I posted the question on the Mach 1 forum and what I got was that the GT's for the most part had 6 bolt cast cranks though the '99'/'00's(some) had 8 bolt cast cranks. Have never had my tranny off but if I get the converter I have sitting here installed I will see what my '99 has.
The Mach's did indeed have forged 8 bolts(Cobra's also of course) with sticks and cast 6-bolts with the automatics.
#13 ·
Windsor engines had the eight-bolt crank, Romeo's the 6 bolt crank. Count your valve cover bolts....11 Romeo....13 Windsor
#14 ·
Thanks for that bit of info! Is one preferred over the other for some reason? Blocks that is.
#15 ·
From what I understand the name just denotes where it was built. There are differences though between the blocks which makes some parts non-interchangable. There is no difference in durability that I am aware of between the two blocks.
#16 ·
There is no difference other then the number of bolts on the cranks. They are both just cast cranks. Ford has always been a royal PITA when it comes to parts being interchangable.
#22 ·
I love how Ford just changes random shit all the time. They do this on all cars. It's got to cost them more money to make all these changes.
#23 ·
It's probably 6 to 1, half dozen to the other. They save money buy using left-overs, but machine work can be a PITA.
Can one use this as the rule?:
If it's a 6bolt crank, it's cast. If it's an 8bolt from a 2v it's cast, from a 4v it's forged.
Will that work? or were there older 8bolt 32V cranks that were cast? (IE lincoln MarkVIII)
#29 ·
Sullivan Performance says there were some 6-bolt Forged cranks but it seems no-one has ever seen one. By the way I have an 8-bolt that will be scrapped unless it is bought by somebody very soon and I will sell it cheap due to you paying the shipping should anybody want an 8-bolt Windsor from a '99 GT, cast of course. Make a reasonable offer ands it's yours. Cast or forged I have never heard of a crank breaking and most will never have the power to do so. The cast is lighter. Sure if I had a forged I'd use it but would not go out of my way to pay the extra for one being NA. This is a knife edged crank also. Mark
