Wanted to share this with the modular community...especially Turbo (read: oil sensitive) stangers. I recently installed an autometer oil pressure gauge in addition to the factory gauge. Let's just say that I'm glad I don't run thicker than a 20W oil.
On a cold start up, the oil pressure in my car is close to 100 psi!!! I have a stock bottom end. When it's warmed up the oil pressure (OP) will drop to 18-20 psi. During normal driving, the OP will hang near 50 psi down to around 20 at idle and up to about 60 at WOT. But when cold, the OP will be more than 100 (gauge pegged) at times.
The scary part: Through out the entire psi range 15 -100+ psi my factory oil pressure gauge NEVER MOVES!!! For turbo guys, I HIGHLY SUGGEST an aftermarket pressure gauge and some kind of restrictor in your turbo(s) to keep that level of pressure from annihalating your seals. For everyone else, just because your gauge registers pressure, doesn't mean it's safe to smash on the car. Be kind, let your car warm up all the way before smashing on it.:tip:
