I posted this over at SVTperformance and some opinions were that it was the PCV system, others think its a possible Valve Guide.
First thing was that the car did it only on start up once in awhile (normal) but when I was dyno'ing i noticed that a small amount of blue smoke would roll out when the rpm's came down from redline. This was only after the 3rd/4th run.
A few weeks later I had a Spark Plug pop out of my head (#8) and ruin the threads in the head. I had the head hellicoiled (time sert insert) and all was good. I also had a compression test ran and got 208 on all cylinders (#8 got 207) so my bottom end is good.
I changed the oil and from that point for the next 4-5 days it burned oil on every start up and when the rpms were coming down (decelerating). It would not burn oil under load. I checked my PCV valve and all seemed good. A few days later it pretty much went away.
Periodically though it still smokes on start up, but not a small puff, I mean a nice sized cloud. It also consistently will smoke when the engine is revved on decel.
I recently went back to the dyno and teh car smoked when decelerating from a pull pretty badly but was clear under load.
My question is, is this a valve guide that has gone bad or something else. What options do I have and am I looking at a possible engine failure or just harmless oil burn off.
I have breathers that I will be putting on soon to see if that helps.
I'm planning on having to eventually replace the heads but would like to wait until next year if possible.
