Ford's way to burp your cooling system!!
76K views 9 replies 6 participants last post by  BBCOBRA04
Why is that ? Please explain ! Thanks .
Id love to know a better way .
Which part are you asking about? If it's in regards to the relocated thermostat, I think it's the fact that you no longer have the low-point flow division created by the OEM thermostat. The Evans unit is up top and downstream of the engine. I simply fill through the expansion tank until full, cap it off, fill through the burp plug until full, heat cycle the car, individually check the level in the tank and the crossover tube and top each off if needed. I sometimes repeat this a second time. No issues!
