Think ford will ever put coyote heads on a big block?
7.6K views 6 replies 6 participants last post by  gregsdart
coyote heads
I believe you have already gotten the answer to your question. The power increases at Ford are turbos. Not a bad idea in my mind. A Boss motor with a bit less compression and two hairdryers on it. Instant 600 hp, and room for much more.
motor
You cant just put coyote heads on the 6.2., its an entirely different block and bore spacing. The problem with the mod motor is the small bore spacing. The 5.8 trinity is about as big as you want to go and even that size needs premium parts to allow it to rev safely. Not saying you cant do it but it requires very high piston speeds.
On top of the expense of altering the heads, basically redoing the whole head to fit is the fact that it would have limited use. Bu I do agree, a 400+ cube motor with a head that is that efficient, plus twin turbos would be absolutely insane! It could START life at about 900 hp, and grow from there.
