41 - 52 of 52 Posts
Anyone do this with a whipple? I'm wondering how you plugged the hole in the intake tube and what size plug I need for the threaded whole on the blower inlet.
Discussion starter · #42 ·
Here's another option for those that may want a slightly larger breather. The K&N 62-1480 breather has an ID of 1 3/4", - slightly larger than the OD of the oil filler tube but will fit just fine when clamped down. This breather has a height of 2" and an OD of 3".
All of these K&N vent filters retail for less than $20 ea.
Discussion starter · #45 ·
Now that you've had these on for a while, I was wondering if you noticed an odor or residualy oil on the valve covers?
Discussion starter · #47 ·
None
I just did this mod a few days ago. Thanks for posting the part numbers, 5/8 vac cap would have been tough to find......Works great........No smell, no oil(yet), and best of all no worries that my old setup is causing a vac leak.........I was also suprised to see how much air can move through those K&N filters. I was origionally looking to get larger ones, but really no need.........:good:
Ok so, if the two tubes that evacuate vapors from the crank case do so at a rate defined by the size of the out lets and the positive vacuum applied by the fact that they are connected to the engine intake. Any fuel contamination caused by the ring blow by would only evacuate as vapor.
If one was to modify the PCV system by disconnecting it from the intake system essentially allowing the vapors to vent to atmosphere and this modification allows the process to occur more efficiently.
Someone please explain.
  • How can the crankcase be evacuated more efficiently through the same size out lets with out the positive vacuum?
  • How could the fuel vapors produce more oil contamination if it is being vented at a higher rate?
  • Why would you not open the oil filler tube in order to allow more volume to escape?
I am not being a smart ass; these are questions that occurred to me while reading this thread. I intend to do this, but I would like these questions answered before I do. I do not like the idea that this oil vapor is leaving oil residue in my engine intake system.
I already posted that their is better thread than this one on PCV stuff. It has the answers to this and many more questiuons.:ilovemf:
41 - 52 of 52 Posts
