I am going to be installing an Evens remote thermostat and water outlet. Evens recommends mounting it on the top of the engine on the inlet side of the radiator. My questions is: would it be bad to mount it in the stock location on the outlet side of the radiator. The bypass circuit will still be in place and should work the same way allowing the coolant to recalculate until the engine is up to operating temperature. Mounting the thermostat on the bottom will “package” a lot better then on the top because the tight space between the water outlet on the engine and the radiator inlet.
Is there a reason why you shouldn’t mount the thermostat on the bottom like the factory set-up?
