Ok guys, I am getting ready to pull the Blower (KB 2.2) back off to do the 60's. I was wondering if it was worth it to do the RR spacer?? I mean what do I gain vs. the $220?? Thanks for any thoughts.......
~Dan
~Dan
do you know off hand if I need the spacer just to make the 60's work?? Will the rail clear the plenum with the 60's installed? Thanks Bill!2kbill said:I have the spacer, and if I had need to change injectors, my blower wouldn't have to come off. To me, that's the primary advantage of the spacer.
technically, 'no', but realistically 'yes'. if your pulling your blower off its worth it. keep in mind though they are generally not on the shelf. mine took a month or so to arrive.Dan_Soprano said:do you know off hand if I need the spacer just to make the 60's work?? Will the rail clear the plenum with the 60's installed? Thanks Bill!
you guys have them in stock Jared?BoostAddict said:Dan,
The stock rail should barely clear the plenum with the 60's. If you ever needed to swap them again or run aftermarket rails you would benefit from the spacer as the Aftermarket rails will then fit and the injectors could be removed without removing the blower. Thanks, Jared
