Just bought a Teksid 4.6....how thick are the cylinder walls?.....does anyone know what the maximum bore would be and still be safe for 16# boost and juice and to remain cool enough for a DD in southern (high 90's/ low 100's) weather...?
Personally I don't buy the arguement that the stock block is just as good.Larry, what is the reasoning behind going to a teksid block? From what I hear the stock 4.6 is just as good.
Does the teksid have the webbing? I can't remember if it or if the stock does.Jeff, the stock block is a good block...but the Teksid is by far a stronger molding. Look at the valley between the heads. notice the metal that is missing on the stock block. In an aluminum block, warpage and torque twist can kill you...all the parts and bearings in the motor can be perfect, your machining can be a work of art, the build can be done in a sterile environment, and then the first time you get that block hot and stress it with 16 # of boost, you get a little warpage and then you have this nice, neat trail of parts down the strip.
Bottom line is that I got it because it is a stronger mold and it was cheap....and they are getting rare.....
Since I have absolutely no self control when building a motor, I like things to be as strong as they can possibly be....as I said earlier, in 40 years of racing, I have never been able to blow up any motor I've built..this will not be the exception.
I agree with everyting you stated but on these cars a high pressure (stock 2005+) oil pump is required for the VCT to function properly.I think that both "views" have their merits. Personally, I go by what has worked for me in the past, without arguement, truly a small sampling. However, by never deviating from my philosophies of how to build a motor, I have never lost one. So, I will stick with that.
Rule #1 Choose parts that will handle a minimum of 2 times the stress you are going to put on them.
Rule#2 Make sure all machine work is within a .0001 tolerance
Rule # 3 Balance all rotating components to within 1/10th of a gram
Rule #4 Polish all parts before assembly
Rule #5 Floroscope all parts before assembly to check for cracks and air bubbles
Rule #6 Check all oil passages and water passages for blockages, even if it is a new block
Rule #7 A high volume oil pump is far better than a high pressure oil pump. I always use a stock rating oil pump.
Rule #8 Have all torque wrenches and measuring tools calabrated before using them (especaily if you haven't used them in a while)
Rule # 9 Don't let your friends help you build the motor
Rule #10 Take your time. Take lots of breaks, don't get in hurry.
