TR6060 Transmission Info
17K views 17 replies 15 participants last post by  DISTRBD
#1 ·
The Shelby uses a Tremec TR6060.
Gear Ratios:
1st: 2.97
2nd: 1.78
3rd: 1.30
4th: 1.00
5th: .80
6th: .063
Final: 3.31
Uses a 26 spline input shaft.
Any info you have about this trans post up!
#4 · (Edited)
08 Vette LS 3, 430-450 HP T-6060 tranny.
I posted this months ago over on SVTperformance.com the new vette is fast! It's faster than a stock GT 500.
Not faster than a modded one though.
Eric: I still can't get on this site from home!
Tim:beerchug:
#6 ·
Tim:beerchug:
Yep, I have heard the same on the specs. I am waiting for the 08's before I decide between that and a GT500.
#5 ·
I had a prototype in my hands at one time. Dimensionally it is identical to a T56 with exception of the tail section being different. Shifter mechanism is identical to that of the 05+ GT Mustangs in that it is a remote mount unit.
#14 ·
Close, but not right on the synchros, see the middle paragrpah below-
So you might be wondering exactly how a Tremec TR-6060 compares with the T56 you know and love. In short, it's better in just about every way. It can handle more torque thanks to a move from a 10-spline input shaft to a 26-spline unit. Moreover, the new case is stronger, the countershafts are one-piece units, and the gear faces are wider. All these changes add up to much greater strength, which we'll all appreciate after we start modding these cars. What we noticed while driving the car, however, was its easy, precise shifting despite the factory shifter.
The prime movers in the better shifting are increased synchronizers on all the gears. Where the Terminator T56 had only two synchros on the 1-2 and 3-4 shifts and single synchros on the remaining gears, the TR-6060 offers triple synchros on the 1-2 and 3-4, and dual synchros on all remaining gears, including Reverse. Plus, the synchronizers have been upgraded from a carbon-particle paper to a sintered-bronze material.
A larger input shaft, beefier gears, more synchronizers, closer gear ratios, and more make this six-speed one that should become a popular aftermarket upgrade.
So this transmission shifts easier, but it also offers a shorter shift throw. "The synchronizer hubs are much narrower, reducing fore and aft shift travel," Tremec's Jim Averill explained. "Additionally, the hub system uses three encapsulated ball-and-coil-spring struts that are much more precise than the old-style hoop-and-stamped strut. This also adds to a smoother fore, aft shift."
#10 ·
yes it does, but i hate a hydraulic clutch, i would much rather a cable, but hopefully ford won't have all the problems the ls1 guys have, i know i had plenty of problems with mine in a t/a, fluid overheating and clutch pedal gets spungy or trying to do the drill out mod on it to get faster flow, once the fluid would get hot you couldn't speed shift, it would just grind the gears and not to mention the 3 slave cylinders that broke and you have to take down the tranny to replace it.
