Somebody has to be working on this.... :rock:
I've gathered what info I can off the net, etc... and there isn't much out there yet. Bellhousing is the same. Motor mounts I hope will work as the Coyote and Boss go in the same pickup suspension, at the worst the bosses should be in a location that will work with some custom mounts. Pan is rear sump. I believe the firing order is different, but some re-wiring of a stock 2v/4v harness can fix that. With a manual t.b. and VVT lockouts it seems like it would be similar to a 3v swap for control. The one big downside (assuming it fits) is weight, shipping weight is listed as 625 lbs, not sure how much extra for the crating but regardless its a big bitch....
So, who's gonna be the first? :hmm:
:headspin:
:headspin:
